Hardware Recommendation - Small Portable Air Compressor
I have a client that operates a rail car facility with 17 folding gangways.
Normally the gangways are operated using 80-psig nitrogen from header.
For nitrogen outages, the client wishes to use a small portable air compressor.
The vision is for the compressor and driver (gasoline) to be mounted on a wheeled cart.
Due to engine sparks, the air-to-nitrogen connection would be in a non-hazardous area.
Operation of only one gangway at a time is needed for emergency outage.
One gangway requires 40-scfm gas (air) at 80-psig.
This is admittedly a small gas flow.
Any hardware recommendation (that works well) would be appreciated.
A vendor recommendation would also be welcomed
Thanks-in-advance
Chance17
Thanks-in-advance
Chance17
RE: Hardware Recommendation - Small Portable Air Compressor
Airsmybag
