surface with multiple patch nx8.5
How to create a surface with multiple patches?
Input:
1 section and 2 Guides
please refer the file attached.
Mathi K
Input:
Mathi K
RE: surface with multiple patch nx8.5
You need to use Split Output Along Guide
Didier Psaltopoulos
http://www.psi-cad.com
I need to use 2 guides for my surface output.
Mathi K
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Is there any other methods or work around for achieving the same?
In CATIA the designer can able to create this type of surface and the same he expect in NX too.
Thanks in advance,
Mathi K
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Please find the image.
Mathi K
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
If we could able to see the multi patch when we use the single guide,why not the same behavior is happenning if we use multiple guide(the one which CATIA does- image attached in previous post).
sorry.I may not be the expert to give you the reason why the behavior is needed? I just conveyed the CATIA designer's requirement,who rapidly changes his design as per the STYLING requirement.
Mathi K
NX9 Win8.1 64bit i7-3770K 16GB Quadro2000
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
