Using accelerometer for FFT of guitar soundboards
Hi I want to use a miniature single axis accelerometer to record guitar soundboards resonances.
I'm considering buying a used one from ebay (PCB 352A21 10mv/g). But from what I have read they have a rather limited life span, is this the case, Or can they simply be sent off to be re-calibrated?
Also if I buy accelerometer, signal conditioner and connecting leads, could I simply just plug it in to my soundcard and start recording, or do I need anything else such as calibration equipment ect.
RE: Using accelerometer for FFT of guitar soundboards
I've used 10 year old accels quite happily. we get ours calibrated once a year. I think for investigative use rather than legal orhomologation that having a calibrator is a bit unneccessary. We used to calibrate every mic channel every day but it isn't really necessary.
That is avery insensitive accelerometer you'd be much better off with a larger one. although that will affect your results due to mass. ideally you'd use a non contacting method such as capacitve or laser. or even a close coupled mic.
Cheers
Greg Locock
Yes that is the problem too much mass would effect the resonance, clearly accelerometers just aren't the way to go so I guess I'l stick with my condenser mic.
cheers
Alf
