Terminal or Connectors for Charging Base & Hand control
I was wondering if someone knows of a place that has some information on connectors and/or terminals for use in creating a connection between hand controls (like TV remotes) and charging bases. I am not even sure if the words I have used in Search engines are the correct words to help in the search. My searches have turned up very few leads. I see many different styles of connectors used in Cell phones, cordless phones, among others.
Just cannot figure out how to find information on them.
John
RE: Terminal or Connectors for Charging Base & Hand control
I have made charging bases for HT's and remotes. I just used Maxim charging IC's and either plated wire or plated metal strip for contacts on the unit and base. You could go to a thrift shop and buy a used cell phone charger to scavenge the parts for your use.
Foxfur
