ASPEN Shell and Tube Heat Exchanger Design
I am designing a condenser for a binary system using ASPEN's heat exchanger design program (*.EDR) version 8.4. You can pick different models to describe the VLE data but for some you have to enter the interaction parameters. Any ideas on how to get those? I have modeled the system uring APSEN parameter estimation but don't see anything I can pull out of that for the heat exchanger design program.
RE: ASPEN Shell and Tube Heat Exchanger Design
