How to change size of displayed measurement
Does anyone know how to change the size/spacing of the displayed measurement on the screen? When I use the "Measure Item" for an XYZ of a point, the resulting values are stacked very closely together, making the values very difficult to read.
I've attached two images. One image is what it looks like when I do a measurement. The 2nd image is from an internet search, showing the dimensions spaced so they can be read easily.
Thanks in advance!
-Kevin
http://files.engineering.com/getfile.aspx?folder=5...
http://files.engineering.com/getfile.aspx?folder=f...
Thanks in advance!
-Kevin
RE: How to change size of displayed measurement
I don't think is possible, even in automation... I searched for SpaceAnalysisInterfaces MeasureSettingAtt (Object) and found nothing about changing size of the fonts...
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Thank you for the response.
I couldn't find anything in the settings as well. I've noticed many images online showing "readable" spacing in the resulting measurement, which made me curious on how to change the display. Not sure if you noticed the two images I attached, but one image is very clear to read, while the other image (one generated from my Catia session) is very close together and hard to read.
Anyway, thank you again for the response!
-Kevin
--Doug
