Backfill Problem - Mononobe Okabe Equation
thread255-95878: Seismic design of Retaining walls
Referring to previous post (link above) and other post that were closed, I have some clarifications about Lateral Earth Pressure
What is the remedy if the backfill slope is great in such the mononobe equation nor the coulomb equation be messed up?
RE: Backfill Problem - Mononobe Okabe Equation
Since slopes are rarely infinite like the equations assume, it is possible to use a trial wedge analysis that may converge on a solution when a slope breaks such that an answer can be obtained. It is also possible to physically limit a wedge search such as only considering a zone that goes back 100 feet for example.
A trial wedge solution will go back infinitely for an infinite slope and never converge on a solution which can be thousands of feet behind a wall. This is not very realistic as the failure surface is not planer but circular or log spiral in nature but it is the way a wedge analysis works.
The poor man's solution is to set the negative square root portion of the equations equal to 1 and get an answer. It is not correct but it is an answer which might give you a Ka = 1.2 or thereabouts.
One can also run a global stability analysis of an irregular back slope condition and determine the amount of thrust resistance the wall has to provide to arrive at a safe situation (FS > 1.5 or whatever), similar to the wedge analysis.
Then there is cohesive strength which the equations can not deal with either. It is a big headache that requires different approaches to get answers that make sense and not just grinding formulas.
The concept is simple, sweep a bunch of wedges and see which one provides the greatest thrust. The model gets complicated if there are many changes in back slope geometry which is why some prefer global stability analysis as those programs allow the input of irregular back slope conditions to analyze. However, they do not provide a direct solution to lateral earth pressure so you have manipulate the software to get an answer.
Soils are hard to deal with so the exercise is to get a reasonable magnitude of thrust on a retaining structure then provide enough resistance to be safe. Seismic analysis is a problem because loads are displacement related and yielding structures can absorb a lot of energy thus the pseudo-static loads are less than a more rigid structure.
Practically the other methods that can be used if the MO cant be used also include the generalzed limit equilibrium
However, a break in the slope and it solves, a little cohesion and it solves and so on. You just can not use equation solutions and have to use a method that reconciles force equilibrium in some manner that solves. Even when you do this, you may not like the answer but at least you have an answer to start tweaking from.
Very Truly Yours,
- andru18
