gap in a socket weld carbon steel 2 inch
I have been welding socking valves for a while never giving a gap. The way I have been reading I should have had problems with cracks. All welds are under 250 psi. No problems yet. Do the cracks show right after or over years. Should I worry about past welds
RE: gap in a socket weld carbon steel 2 inch
Stupid is as stupid does. One can run stop signs and stop lights for many years before the final crash. "But that is the way I've always done it." is little comfort to the people injured or the families of the deceased.
If you are willing to gamble with lives, it is best that you gamble with your own. Take up skydiving without a parachute and leave pipe welding to the professionals.
Best regards - Al
the greatest risk is in high temperature services, and especially where dissimilar metals are involved.
The metaphor regarding "running stop signs" is spot-on.....
Some companies offer devices to ease "fit up time" and ensure that the proper gap is made:
http://www.galgage.com/measuring_gap-a-let.html
This topic has been discussed on this forum many times:
http://www.eng-tips.com/viewthread.cfm?qid=330514
http://www.eng-tips.com/viewthread.cfm?qid=10800
MJCronin
Sr. Process Engineer
Venture Engineering & Construction
www.VentureEngr.com
