Tolerances and part costs
We always throw around the well worn phrase that tighter tolerances increase costs. I can understand that in many respects but what about the cost of inspection fixtures, like shown in the link, that have to be an order of magnitude more accurate than the part itself? On a low quantity purchase is there much cost difference if ask for +/-.002 vs .008 on the dwg if I need to make a fixture that is +/-.0001?
Link
Link
RE: Tolerances and part costs
For low volumes, not so much.
Luckily, sort of, there are CMMs, which are equally costly at low and high volumes.
Mike Halloran
Pembroke Pines, FL, USA
What tolerance doe the part need to function correctly? That is what goes on the drawing.
Use tol on the part(s) that work in your design, design the fixture tol so it fits.
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
DGallup: I agree that tol should not be any tighter than what is reqd. However, I often find that I can take multiple approaches depending on how tight I can get a feature on the part, and if tighter is not really that much more costly why not ask for it. For an everyday example consider the feel of a well made tool vs. a cheap one. Both can do the job but who doesn't prefer the better made one.
T&B: Same at my company, next to impossible to get feedback as to why some parts which appear to have equal complexity are very different in price. I have seen some get purchased at $X and next round of quotes come back with half or double $X. Maybe depending on how hungry the shops are?
E.g. if a supplier can get 90 parts out of a sheet of something, and you order 100, he has to buy two sheets. He may be able to use the remainder for some other project, but you will pay for that material anyway. So it may pay to minimize the size of your parts, or design them to nest neatly, or select your order quantities carefully, coordinating with your supplier and his supplier.
Similarly for bar stock.
Mike Halloran
What I think is expensive is narrowing the 3 sigma distribution of variation, but that can pay off in lower assembly and warranty costs, which are even harder to track on small quantities.
As Mike Halloran says how much oversize the original stock has to be or how many parts you get from a sheet/ bar will have far more impact and something like one small radius as an inside corner on a deep pocket will have a major impact.
