Combined 2-Cross Section Column Equivalent Effective Length Factor
I know this topic had been discussed before in this forum by others, but I can not find the original discussed post, so I would rather post my question again.
Please see attached pdf file assuming all ends are pined ends, basically I am trying to find if there is a quick approximate method to estimate the Equivalent Effective Length Factor.
for example, in diagram (B), can I consider this way: top 10' W12x72 column will have a buckling curve along x-axis(top column's weak axis), however bottom 10' W12x72 column will have a buckling curve along y-axis(bottom column's weak axis), so the final buckling curve of the combiined column will along 45 degree between x-axis and y-axis, therefore I can take k=0.707, and get:
kL/ry = 0.707x240"/3.04 = 55.8.
Do you guys think above reasoning is valid or not?
RE: Combined 2-Cross Section Column Equivalent Effective Length Factor
