Minimum clearance of lighting fixture in T-bar ceiling
I wanted to inquire if there is a standard clearance of various material and equipment in plenum space of standard T-bar/suspended/tiled ceiling such as insulation, supply air diffuser, heated air diffusers, ducts, smoke detectors, etc., from 2' x 4' or any standard recessed fluorescent fixture.
Thank you.
