Performance curves on simulink
I want to use a performance curve of a turbine in a simulink diagram. Can anyone tell me if there is a block or a tool in simulink wich I can use to put this characteristic curve?
Tks in advance!
RE: Performance curves on simulink
Well I have two inputs. One of them, for now, is constant the other is a sinusoidal function. These two inputs combine in a specific formula which gives a value that I must then match in a performance curve. How do I build a block wich is a "performance curve"? Use some kind of array?
I've found something on the internet wich I think is the block I need but I dont know really wich is:
It's a lookup table.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
