Create a group from Excel list
I have a CATProduct open (500 parts), I have an Excel file that give me the name of 35 specific parts of this CATProduct. I would like a macro that could create a group with these 35 parts.
I have digged into the search options, I am thinking that a solution could be with personalized query, but I cannot find anything relevant.
I am using Catia V5, R20.
Thanks for your help,
Marc
RE: Create a group from Excel list
500 different parts in the assembly, just one instance ? this should not be too difficult... what is you code so far?
Eric N.
just for start..
CODE -->
Sub Selecttt()
Dim sPath As String
CATIA.DisplayFileAlerts = False
Path = "C:\Products.xlsx"
Set xlApp = CreateObject("Excel.Application")
Set MyXL = GetObject(, "Excel.Application")
Set MyXL = GetObject(Path)
MyXL.Application.Visible = True
MyXL.Parent.Windows(1).Visible = True
For i = 1 To 3
sPath = MyXL.Application.Sheets(1).Cells(i, 1).Value
 Set ActiveProductDocument = CATIA.ActiveDocument
 Set Product1 = ActiveProductDocument.Product
 Set Product3Products = Product1.Products
 Set Product2Dot1 = Product3Products.Item(sPath)
Set selection1 = ActiveProductDocument.Selection
selection1.Add Product2Dot1
 Next i
 Dim myGroups
Set myGroups = Product1.GetTechnologicalObject("Groups")
Dim myGroup As Group
Set myGroup = myGroups.AddFromSel
CATIA.DisplayFileAlerts = True
End Sub
Thanks for your answers!
It looks like it's a bit more complicated. Indeed I use Catia on a UNIX station, so I would probably not be able to use this Excel sheet... Do you think I can instead use a txt file ?
I tried anyway to launch the macro, it stopped on the Line 29, column 6: "Next i", with the following error: "expected end of statement"
Ok, I worked on this and thanks to your code and this website http://v5vb.wordpress.com/2010/02/08/file-dialogs/... I found how to read a txt file. I tried mixing your code with the other one, but I still have an issue:
CODE -->
Sub CATMain()
Dim strFilePath As String
Dim objFile As File
Dim objTextStream As TextStream
Dim strLine As String
'Display file open dialog
strFilePath = CATIA.FileSelectionBox("Select Text File", "*.txt", 0)
'If user clicked cancel (empty string is returned), then exit the program
If strFilePath = "" Then Exit Sub
'Open the file, add the 10 first parts to the selection1
Set objFile = CATIA.FileSystem.GetFile(strFilePath)
Set objTextStream = objFile.OpenAsTextStream("ForReading")
For i = 1 to 10
strLine = objTextStream.ReadLine
Set Product2Dot1 = Product3Products.Item(strLine) '<<< Here is where it stop "The method Item failed"
Next
objTextStream.Close
End Sub
Do you have any idea how to solve this ?
Try with the instance name of the parts or products in the txt file...
I tried, still the same error.
I also tried with the PN, I tried with the name as displayed in graph, same thing...
I don't know what the problem is, but just in case.. look if you text file contains less that 10 lines.. or in other words, be sure that you are passing valid strings.. not empty strings.
one way to know.. change the number of iterations to 9.. and check if the error appears.
or maybe with message boxes..
It looks like it's related to the name I am using. I tried a short sequence of the code above, and I can't make this line works: Set Product2Dot1 = Product3Products.Item("XXX")
CODE -->
Sub CATMain()
End Sub
Any name I am using give me the same error "The method Item failed". I cannot figure out how to use this ".Item".
try the online doc:
Quote (online doc)
o Func Item( CATVariant iIndex) As Product
Returns a product from its index in the Products collection.
Parameters:
iIndex
The index of the product to retrieve in the collection of products. This index can either be the rank of the product in the collection or the name you assign to the product. As a numerics, this index is the rank of the product in the collection. The index of the first product in the collection is 1, and the index of the last product is Count. As a string, it is the name you assigned to the product using the
AnyObject.Name property
Returns:
The retrieved product
Example:
The following example returns in ThisProduct the third product, and in ThatProduct the product named Wheel in the CarParts product collection.
Dim ThisProduct As Product
Set ThisProduct = CarParts.Item(3)
Dim ThatProduct As Product
Set ThatProduct = CarParts.Item("Wheel")
Eric N.
Thanks Fernando, I'm getting closer and closer :)
One last issue: I don't know how to add a selection to another selection. In the code you provided, the selection selPN is changing at each loop of the "For Each strLine in arrLines". But how can I store this information and add it to another selection ?
I thought of using a collection (like cnc07 in this Post) but the declaration "As New Collection" give me a error "Expected end of statement".
Marc
Here I am again!
I finally managed to do what I wanted, it's working on my windows PC. But it's giving me the an error on my UNIX station, without any description of the error:
CODE --> CATScript
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim selPN, selGL As Selection
Set selPN = productDocument1.Selection
Set selGL = productDocument1.Selection
Dim Producttemp As Product
Dim objFSO, strTextFile, strData, strLine, arrLines
CONST ForReading = 1
'name of the text file
strTextFile = "H:\test.txt"
'Create a File System Object
Set objFSO = CreateObject("Scripting.FileSystemObject") '<<< HERE IS WHERE THE MACRO STOPS AND GIVE ME AN ERROR
'Open the text file - strData now contains the whole file
strData = objFSO.OpenTextFile(strTextFile,ForReading).ReadAll
'Split the text file into lines
arrLines = Split(strData,vbCrLf)
'~ 'Step through the lines
selPN.Search "Name=" & "*" & strLine & "*" & " ,all"
SelPN.VisProperties.SetRealColor 0, 0, 255, 1
Next
SelGL.Search "Color=Blue,all"
'Cleanup objFSO
Set objFSO = Nothing
End Sub
Does anybody has an idea ?
You're right, the file path is different, but I changed it while copying the macro on my Unix station. (/Myserver/myfolder/test.txt)
Actually the code is stopping at the next line:
CODE --> CATScript
Unfortunately I don't have now access to a UNIX workstation (not even remote) and cannot check the code but you should use something like bellow (you need to forget Windows methods and put some MsgBox to check your code)
Instead of
Use
set fs = CATIA.FileSystem
dim strTextFile as File
set strTextFile = fs.GetFile("/Myserver/myfolder/test.txt")
MsgBox strTextFile
dim ts as TextStream
set ts = strTextFile.OpenAsTextStream("ForReading")
do while ts.atendofstream=false
''''''.code to read the lines
loop
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Thank you for your answer.
I am going to work on this, and come back here to get you a feedback.
Yeah ! It's working, here is the code:
CODE --> CATScript
Sub CATMain()
On error resume next
Set fs = CATIA.FileSystem
Dim strTextFile as File
set strTextFile = fs.GetFile(CATIA.FileSelectionBox("Select Text File","*.txt",0))
Dim ts as TextStream
Do
Dim Lire as String
Lire = ts.ReadLine
MsgBox Lire
selPN.Search "Name=" & "*" & Lire & "*" & " ,all"
Loop while ts.atendofstream=false
SelGL.VisProperties.SetRealColor 0, 0, 255, 0
'Cleanup objFSO
End Sub
Thanks for your help !
