NX 8.5 Sketxher
NX 8.5 Sketxher
When I mirror curves in sketcher and constrain geometry to them. The mirrored curves are not perfectly mirrored. Is there a setting that I need to change? See attached model.
RE: NX 8.5 Sketxher
There appears to be a problem when mirroring sketch curves depending on what you use to define the mirror Axis. In your sketch, if you select the 'Y' Datum Axis of the Sketch CSYS as the mirror Axis, you get the incorrect results that you found. However, if you select the 'Y-Z' Datum Plane as the mirror Axis, then the results are what you expect, a 'perfectly' mirrored curve.
I'm going to try to duplicate this behavior in a new part file and if I can I'll open a PR. No matter what I do, I would recommend that you contact GTAC and have them open an IR/PR using this part file just in case it's part specific.
Anyway, for now try to pick the Datum Plane instead of the Axis when mirroring Sketch curves.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: NX 8.5 Sketxher
see attached image.
Tomas
RE: NX 8.5 Sketxher
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
