Orientation of flow orifice
How flow orifice orientation effect the reading of flow??
RE: Orientation of flow orifice
Orientation? Of what?
- The Line?
- The Flange Taps?
- The Plate?
"Better Questions earn Better Answers?
Jop
prognosis: Lead or Lag
for common plates there are correction factors for the inevitable case where it is installed backwards.
but the question I think you are asking, is to install the paddle pointing upward
If flow meter installed in verticle line, what is effect on flow reading?
usually no effect, but usually recommended that liquid flows-up or horizontal and gases with condensible components flow-down or horizontal.
thanks guys
In liquid stream if orifice installed in vertical line, than what will be effect on flow reading?
