Aviation Ball Marker on Overhead Line
We are looking at adding some of the orange aviation ball markers on an overhead line that we own, primarily to improve visibility for equipment that may work in that area. One concern that was raised was the additional loading on the line. I have looked thru the NESC C2 and could not find any references to aviation ball markers. Is there any design considerations or is it such a small item that it is inconsequential?
Thank you
Thank you
RE: Aviation Ball Marker on Overhead Line
If you need vibration dampeners or armor rod at the marker ball locations, be sure to include the weight of those as well.
As well, they are essentially a concentrated point load on the conductor, so armor rods are often added to provide mechanical strength/protection.
Your local aviation standards likely specify the size and spacing of the markers.
I've heard of some utilities using aerial marker CONES rather than spheres as some (older? bolted?) designs were prone to coming apart, leaving only half a cone in the air.
You may want to consider/checking loads created by maintenance people in the future. Eg, conductor carts are often used by maintenance people to inspect the markers over the waterway. Is your conductor in good condition, are your structure supports and hardware sufficient to support that load? If not, can/do you perform helicopter maintenance?
