Testing an epoxy material for a membrane
I am constructing a device. I have to test a membrane material for that device which would be periodically stretched slightly (locally) and would be in a direct contact with hot wax (also periodically). The material I would like to use would be sort of epoxy (PCB) and of thickness approx. 0.4mm.
I am searching the internet for the information about kind of tests which normally are applied to verify characteristics of such a material. I would be very obliged if someone familiar with a publication about this issue would send a link.
Thank you.
Greetings.
Hilary
Thank you.
Greetings.
Hilary
