closing force for o-rings
in static face sealing situation(two flanges)when there is no internal pressure(just oil hydrostataic pres.)how much force must be applied by bolts to make sure that the oring seals the faces.because of ISO9000 i need a refference for my calculations.
thank you all
thank you all
RE: closing force for o-rings
Your reference is in ASME VIII Div.1 App.2 or any other flange calculation procedure for pressure vessels: the value of y (gasket seating stress or pressure) is zero for Orings.
prex
http://www.xcalcs.com
Online tools for structural design
