Hardness value verifcation
Hi Gents,
I came across an issue with hardness value variation on the 4130 round bars. The details are as follow:
Material: AISI 4130 Round bar, Heat treament condition: Quenched & tempered, Hardness tester used: Brinnel, Hardness values mmeasured: 283-312 BHN, Acceptable limit as per API 6A: 197-235 BHN.
Now our contractor has come up with following statement:
Hardness readings taken previously were not accurate since material was exposed to environmental aging and hence, surface hardness found more.
Now, they had skim the face of raw material and conducted hardness test again and harness values are coming within the acceptable range of API 6A.
Can we accept this variation in hardness before and after surface skimming(slight machining)? Please advise.
RE: Hardness value verifcation
1. There is nothing like environmental aging for steel grade 4130.
2. High hardness can be possible due to following reason:
1. quenched with high severity instead of required: wrong HT cycle followed or part wrongly mixed with other part HT cycle for making full load in the furnace.
2. Improperly heating and quenching causing mixed microstructure and high hardness.
3. Wrong BHN measurement on curved surface with out flat surface preparation or curve compensation set up not available in the Brinell Hardness tester.
4. Sever banding issue in the steel causing poor mixing of micrstructure and high hardness on carbon band.
3. Now hardness within spec may be due to:
1. Supplier heat treated the part again.
2. Improper heating and quenching cycle caused mixed microstructure and resulting different hardness when measured at different location.
3. BHN properly measured with flat surface preparation or curvic surface measurement with compensation setting.
4. How to accept the part:
I hope with the following reports, you can accept the parts:
1. Surface and core microstructure picture at 100X magnification and % martensite more than 90% at 5mm depth range.
2. Core microstructure at 100X and % martensite and other phase.
3. No mixed microstructure on the surface.
4. No Banding or banding with in the hardness specification.
Thanks in advance for your advice.
How else can they give you center and mid-radius hardness values.
And to do that the piece cut off needs to be at least as thick as 1/2D.
Plymouth Tube
