Fluid Flow Rate
Fluid Flow Rate
Sompe production profile I have seen, say:
oil flow rate: 100,000 bopd
water flow rate: 50,000 bopd
Total fluid flow rate: 140,000 bopd
Why the total fluid flow rate is less than the sum of oil and water? Water injection is excluded here. Thanks.
RE: Fluid Flow Rate
oil flow rate: 100,000 bopd MAX
water flow rate: 50,000 bopd MAX
As the water cut increases, oil production tends to decrease. However, at no time would the combined flow exceed 140,000 bpd.
--Mike--
RE: Fluid Flow Rate
