Ideas for inspection scheduling
Evening all,
I'm after a little help.
I'm currently support an inspection area that as I could describe being a "jobbing" shop. The company works for an array of business sectors all with there own level of quality standard.
The company has a number of dedicated inspectors some with different qualifications etc. because of the business sectors the inspection activities range from material certification and cast number checks, dimensional checks of raw materials, in-house machined items, sub-con machined items, fabrications visual, MPI / Dye-pen, painted items / surface treatments.
Everyday more materials / items are delivered and everything is wanted ASAP.
What I'm after is a few visual ways (lean thinking) of displaying what's in the building and what needs inspection. I've put down the challenge for a 2 day turnaround for any items, wether it's an item manufactured in-house or material delivered into the building.
At the moment all the delivery notes are stacked up in trays and it doesn't give a good view of where we are upto.....
I'm looking for a few ideas to get some changes in place.
Cheers,
Ant
Cheers,
Ant
RE: Ideas for inspection scheduling
Harold G. Morgan
CATIA, QA, CNC & CMM Programmer
ASAP is not a measurable deadline. The first thing you need to do is start replying to ASAP request with "There are 74 items in line ahead of your request. Therefore the soonest that it will be possible for us to look at your stuff is next week on Thursday afternoon."
Next, someone at a sufficiently high level of management needs to be made responsible for arbitrating the priority of items at the company level, not the individual project level.
Then you need a way to match inspection requirements for each part or batch to the inspection capabilities of individual inspectors.
Once you get that in place, I think Trello might work for you. https://trello.com/
Then you can collect data, assess priorities, find optimizations.
David
