Single phase 2.2Kw motor blowing fuses
I am not an electrical engineer so I am not familiar with these motors at all.
It is a single phase 240V AC motor. Rated 2.2KW. It has a 16A power feed with a 16A fuse but when the motor is loaded up, the fuse blows.
240V, 16A = ~3.8KW
How is it possible for the motor to draw over 2.2KW or is that not really a set limit, just a limit the motor should not be used above?
I know this is probably really basic but I have no idea.
Thanks.
240V, 16A = ~3.8KW
Thanks.
RE: Single phase 2.2Kw motor blowing fuses
Also, if the power factor is around 0.7 you cannot get more power oout of the shaft than 3.8*.7=2.7 kW. Then, there are other things to consider also. I don't find it mysterious at all.
Gunnar Englund
www.gke.org
"Will work for (the memory of) salami"
Bill
"Why not the best?"
Jimmy Carter
Ah ok. The motor works fine under no load. I have found another motor that is the same apart from the fuse inside is 20A rather than 16A so that was probably someone elses solution/bodge. I also forgot about the power factor with AC so thanks Skogsgurra.
Thanks for the help. We will have to be more careful loading this motor up.
