Circle Esnaps behavior
I'm having trouble snapping a circle to an endpoint of a line. After upgrading to V1R4 my circle snap behavior has changed where it now shows a little yellow box with 000 and if I try to snap to an endpoint of a line nothing happens. I'm guessing this is something simple in the Esnap settings, but I can't figure it out. Any help would be greatly appreciated, Thank you.
RE: Circle Esnaps behavior
I believe I have a similar issue. Unfortunately I do not have a solution but I do I have a workaround. What I do is place the center of the circle as usual, but when then to define the diameter, I click beyond the snap point. Then I select the circle, grab a square adjustment handle, and drag/snap it to the endpoint I originally wanted. I hope the steps are clear, you probably already do something similar yourself as a workaround.
I know it is a little cumbersome but it works and doesn't take that long. I believe it is an error in Draftsight because in AutoCAD I did not have this problem. Let me know if this helps.
Best,
Medeski
No problem, I am glad I could help.
Best,
Medeski
