Heat Transfert Analyse "Temperatur Simulation" (Input File : HTL, HTLA and HFLA not Result
Hi ,
I have got few questions
i am a beginner and i test to do a model on abaqus, that i got it from a friend and i want to Change some things and see the Results.
first off all I am doing coupled thermal displacement analysis using the Input file and a Model Database (*.cae) Assembly that are already done.
In the Input file are the following Information :
** STEP: Heat
*Step, name=Heat
*Coupled Temperature-displacement, creep=none, deltmx=500.
0.2, 1., 1e-05, 1.
** BOUNDARY CONDITIONS
** Name: Chipping Type: Temperature
*Boundary
_PickedSet6, 11, 11, 400.
** INTERACTIONS
** Interaction: WS-Strahlung
*Sfilm
_PickedSurf8, F, 20, WS-Strahlung
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field
*Element Output, directions=YES
HFL, TEMP
** HISTORY OUTPUT: H-Output-1
*Output, history
*Energy Output
ALLAE,
*End Step
I want to add in the Output the belwo Coupled thermal-Analysis :
HFLA : HFL multiplied by the nodal area.
HTL: Time integrated HFL.
HTLA : Time integrated HFLA.
i add it on the Output Field *Element Output, HFLA, HTL, HTLA as well as on the History OUTPUT *Contact Output, HFLA,HTL, HTLA
When i open the Datebase (*.cae) in the Abaqus and i creat new Job using the Input File i get the following Warrings
Output request hfla is not available for element type c3d4t
Output request htl is not available for element type c3d4t
Output request htla is not available for element type c3d4t
and there are not in the Results
and When i Change the Element type : *Element, type=C3D6T(S) i get the followings Errors :
i don't know realy what should i do to get the Results of HTL, HTLA , and HFLA
hope I am clear to some extent and able to clarify the problem.
Any answers to this will be highly appreciated.
** STEP: Heat
*Step, name=Heat
0.2, 1., 1e-05, 1.
*Boundary
** INTERACTIONS
*Sfilm
** OUTPUT REQUESTS
*Output, field
HFL, TEMP
*Output, history
*Energy Output
ALLAE,
*End Step
