Staad.Pro Deflection Check DFF
Hi everyone....
Im using Staad.pro to analyze a structure for some equipments.
I used DFF parameter to verify deflections but in the aoutput I can't see any results.
I have also used DJ1 and DJ2 parameters in the correct way.
Any suggestions?
If I use File-Report SetUp-Output-Steel Design Detail I read this message: "Torsion and deflection have not considered". Well... ok about Torsion....'cause I used Torsion 3 all... but I want to have a deflection check!!!
Thanks to Everybody!
Any suggestions?
