WPQ thickness range
WPQ thickness range
WPQ thickness range
Dear all
I have a welding procedure qualification (test coupon 17.1mm)with two different process GTAW with 2 layers of 5mm and 12.1mm with SMAW.
i want to replace the GTAW process by SMAW process.What is the range of qualification of this welding procedure qualification according ASME lX???
RE: WPQ thickness range
Deposited weld metal thickness is limited to 24.2 mm [24] with SMAW. Base metal thickness max is 34.2 mm [34 mm]
