Profile not sticking
Today when I went into Draftsight, an error popped up and all my settings, alias and custom profiles were gone. I had them saved so I imported them. The problem is, I imported my saved profile and it works fine but when I exit out of Draftsight and go back into it, the profile goes back to the default and I have to reset it again. I don't want to have to do this every time I go into Draftsight. Can anyone help with this?
RE: Profile not sticking
Try this. Create you own profile. Export it. Run Draftsight from command prompt - draftsight /p xxx, where "xxx" is your profile name. If it runs fine modify desktop shortcut.
