Deflection Check with DFF parameter
Hi everyone!
Im doing a calculation for a small steel structure supporting equipment.
At the end I would like to check deflections for all the beams for serviceability load combination.
I used DFF parameter..defined DJ1 and DJ2 where necessary but when I print results from Print-Report-Output-Steel Detail Design
this message is shown : "No deflection check have been done".
Can anybody help me?
Thanks a lot!!!
RE: Deflection Check with DFF parameter
Thanks for your posts...
I had already read them...but I didn't solve my problem....
I put Deflection Check but it doesn't check...I really don't know...
