Cannot get the Legend image shown in reusable partfamily in TCE
Hello NX forum
I play around to get my reusable components to work, and it goes really good, but I still have 2 questions that you may be able to help me with :
Qustion 1: I can´t get the Legend image to work.. I have tried to make a new dataset in the Item Revision of the Part familie master, that is a bitmap file.
In the create KRX file dialog i then type N000897/A wich is the Item rev that the bitmap dataset is placed in.
But the image dont displays when I try to add the reusable object??
In the create KRX dialog there is like a dropdown menu at the selct image menu point, but it is empty.
Is there some place i must define where the image is placed or?
I have attached a word doc. showing how my teamcenter Item looks, and how my edit KRX dialog looks like.
Is it possible to get a screw to automatic find both the correct diameter and lenght ? The diameter I have in place thats no problem, but how do I define the lenght matching in the KRX file ?
Best regards
Jan Hansen
Denmark
Best regards
Jan Hansen
Denmark
