NX 7.5 history problem
When i move a part in modeling [ menu - edit-move object-distance ]:
it moves, but later on i would like to see how much is moved. Where i can find this.
OR : later on i would like to change movement magnitude, how to do that?
I can't find in the tree moving history.
RE: NX 7.5 history problem
If you want the move operation to show up in the part history, make sure the 'associative' option is checked when you perform the move operation.
www.nxjournaling.com
works, thanks
