Using excel commands within a NX macro
Hello everyone
I stepped into a problem while trying to automate a task (I'm pretty novice about NX customization, just starting with simple examples and following the Help guides). I'll try to be as clear as possible:
I need to take some information from the PMI report spreadsheet and place it into a table.
Problem 1: It seems that journaling doesn't support PMI report command (Information > PMI > Report). Is there a workaround to use this command in journal?
Problem 2: Then, I decided to try with macro recording. It launches the Excel spreadsheet succesfully, but I can't find the way to add some excel handling commands to the NX macro (e.g. Copy, Cut, Paste some columns). Is it possible to launch the excel spreadsheet, use these excel native commands, and then return to NX application by using a macro?
BTW, I'm using Windows XP, NX7.5
Any help is appreciated!
Thanks!
Thanks!
RE: Using excel commands within a NX macro
That being said, I'll let some others here respond since they have much more experience creating Journal and perhaps updating them into full-blown programs.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks!
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks!
It will probably be easier to query the PMI object for the desired information and put it in the table directly, bypassing the PMI report entirely.
www.nxjournaling.com
Mainly, I need to get the value, appended text, and tolerances from the PMI dimensions... What do you think?
Thanks!
PMI_dim_table.vb
Other than that, this is just great! exactly what I was looking for. Thank you very much cowski!
Glad to hear it helps.
Thanks!
Best Regards.
Updated code
Best Regards.
I have another question for you, sorry for bring it up after a while... Is that possible to get also the dimensions contained in a whole assembly?. This journal works perfect with isolated parts, but when I'm trying to use it for an assembly, it just draws the headers of the table; which I think is expected because the dimensions are contained in the parts or subassemblies, not in the top assy. Do you think is possible to get the complete dimensions table contained in the assembly?
