precision linear positioning with a ball detent
Hi!
I am looking at feasibility and execution of using a ball detent for precision manual linear positioning in a small, lightweight handheld consumer product.
Will need .001" (or better) accuracy over a range of ~1" travel, with about 30 individual steps. likely using ultem for the main body of the system.
I do not think of a ball detent as a precision system, but in theory, I can not see why not. please discuss, and ask questions as necessary!
thanks
thanks
RE: precision linear positioning with a ball detent
One fixed and one that can be lifted to allow them to disengage and allow movement.
The clearance left-right is going to need "some" clearance anyway, so that requires the hole be slightly oversize anyway. Then, even if the left-right accuracy is 100.0000%, the x-x linear position is going to also be variable by the same hole size. If you don't use a full-depth hole, then the whole assembly could move both left-right (y) and linearly (x-x) sicne only a part of the ball detent would go up into the partial-depth hole.
The cone shape should deal well with wear as long as the mated distance between the two parts is not important. What I mean by that is the parts are constrained in the x-y plane by the cup and cone and have allowable slop in the z direction to allow for changes in mated height due to wear.
Still, 0.001" repeatable accuracy could be very difficult with the small features that would be necessary for 1/30" steps. Could you share more about you application and why you need the high degree of accuracy?
The first stage has course pitch to get you in the neighborhood quickly, then the second stage had finer pitch for accurate positioning.
Mike Halloran
Pembroke Pines, FL, USA
his leaves the ball with point loadingThis suggests using an undulating semi-circular shape on the teeth as it ratchets, so the plastic and the preload need to be low enough to withstand it. If possible, a pre-load relief for when the user is positioning the item.Are you trying to measure a distance or save a distance? If it is measuring, I'd look at using a moire pattern; basically an optical vernier.
