BPSPLOT Error for IDEAS10
Hi Team
We are using siemens IDEAS10 software on my UNIX server to convert cgm to tiff file for a while(Over 10 years).
Suddenly i am getting the following error
LOGFILE /PTO/WWW/bps/pmusr/fcyas047/job_0/logfile.txt
10 Mar, 2014 09:56:51:BPS: SUBMIT_TIME
10 Mar, 2014 09:56:51:BPS: Job 0 Submitted
10 Mar, 2014 09:56:51:BPS: Sending bPrintTo ...
10 Mar, 2014 09:56:51:BPS: Sending myFilename ...
10 Mar, 2014 09:56:51:BPS: Sending myProfile ...
10 Mar, 2014 09:56:51:BPS: Sending /tmp/CTT_FILE_2060.cgm ...
10 Mar, 2014 09:56:51:BPS: QUEUE_TIME
10 Mar, 2014 09:56:51:BPS: Job Ready to Run
10 Mar, 2014 09:56:52:BPS: EXECUTOR: CHDIR (/PTO/WWW/bps/pmusr/fcyas047/job_0)
10 Mar, 2014 09:56:52:BPS: EXECUTOR: pmusr TIFF myProfile CTT_FILE_2060.cgm print_cli
10 Mar, 2014 09:56:52:BPS: EXECUTE: bpsplot :bpsplot_sdrc:
10 Mar, 2014 09:56:52:BPS: RUN_TIME
BPSPLOT: 1.0011 Solaris 2.6Plotting Process: StartedPATH=:/cpy/thishost/unix/cen/cae/c3p/10.1/sun/sdi/bin:/usr/etc:./:/
cpy/thishost/unix/cen/cae/c3p/10.1/sun/bin:/cpy/thishost/unix/cen/cae/c3p/10.1/sun/freeform/bin:/cpy/thishost/unix/ce
n/cae/c3p/10.1/sun/imageware/bin:/usr/bin/X11:/usr/sbin:/usr/bin::/cpy/thishost/unix/cen/cae/c3p/10.1/sun/sdi/bin:Start
Time 10 Mar, 2014 09:56:52
ARGV[ 0] = :/cpy/thishost/unix/cen/cae/c3p/10.1/sun/sdi/bin/bpsplot_sdrc:
ARGV[ 1] = :pmusr:
ARGV[ 2] = :TIFF:
ARGV[ 3] = :myProfile:
ARGV[ 4] = :CTT_FILE_2060.cgm:
ARGV[ 5] = :print_cli:
bReprint FALSE
10 Mar, 2014 09:56:52:BPS: Returned from Execution (0,1,0)
10 Mar, 2014 09:56:52:BPS: Normal Termination Return Code 0
10 Mar, 2014 09:56:52:BPS: DONE_TIME
And the log file looks like
*** Warning: User Recoverable Resource Error ***
Detected loss of communication with I-DEAS license daemon.
Contact your system administrator.
OK - Retry, Cancel - Exit without save.
OK or Cancel? (O or C) Success
Any ideas? Appreciate your help on this.
Thank you
Aatg.
ARGV[ 1] = :pmusr:
ARGV[ 2] = :TIFF:
bReprint FALSE
Thank you
Aatg.
RE: BPSPLOT Error for IDEAS10
Thanks for your reply.
License sever is running fine and validating the license.
I have restarted the license daemon server too. But no use.
Finally got the solution from one of the google post and the problem solved. Now IDEAS10 is working fine.
Added "EDS_ID10_LICENSE_FILE=7610@ecc1nz01.mc2.cpy.com" in the sec.com file.
Still i do not know how it was working previously without this variable and why it is working after i have added this line????
