bystronic 3015 laser cuts and then pauses
We have a Bystronic 3015 laser that has developed an "error STL3511" over the weekend. It starts to cut then pauses and won't start again until the continue button is pressed. Does anyone have a clue where I could get the error code info as our machine came with the basic manual only.
RE: bystronic 3015 laser cuts and then pauses
-HR
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
Check the ultra-pac unit for fault indication (led lights on side of unit) red light means it requires a service.(new filters)
Check the beam path air pressure regulator is set to 2bar.
