column - vehicle impact protection
I have an isolated column that will be in close proximity to where cars will come in and out. Structure is a larger garage/barn accessory to residential. Apart from it being a good idea does any know of a code requirement i.e. ibc/irc for protecting the column from the vehicles? Also, what would be a good approach for protecting the column. Column may be either 8x8 timber or a 4" steel pipe. I was thinking of using a pipe and than casting the pipe in the center of a concrete bollard, would this really protect it though? as the concrete is in direct contact with the column. Isolated bollards around it would take up to much space I think.
RE: column - vehicle impact protection
Try looking at the UFC 4-023 found here.
The Federal Transit Administration, Defense Department, and FEMA have manuals containing details for bollards.
Dik
