450 - 470 MHz Radio Transmission Indiana US
Hi, could some one advice on wha the requirments for transmitting on UHF 2 450 - 470 MHz for Indiana US. Whats the power limit before a license is required. Is there a specific band width to use 12.5 or 25KHz. Thanks Paul
RE: 450 - 470 MHz Radio Transmission Indiana US
You will then need to review the license requirements and restrictions for the various services listed.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
For 450-455MHz is says Fixed Mobile for the Radio frequency Spectrum allocation would that cover transmission of RTK corrections for from a fixed base for conducting a survey? I'm trying to select the service option for a new FCC license application but am unsure as to which service option this comes under, I was considering using around 453 MHz if possible for transmission. Thanks Paul
