Pulse firing gas valve
I am interested in sourcing a manufacturer of gas valves that can be used for an on/off pulse burner system for a brick kiln. I am aware that Kromschroder have the VAS series valves ideally suited for this application....up to 6 pulses/min. However they are only rated to 50kPa. I need a valve rated to at least 100kPa and hopefully higher. The valve has to be specifically suited for this duty. (eg the Kromschroder valves are tested to greater than 3,000,000 cycles).
Thanks in advance.
Rod.
Rod Nissen.
Combustion & Engineering Diagnostics
