Electronic Control of Pressure
Hello all,
I'm trying to electronically control pressure(0-75psi) release from a CO2 tank, and was hoping to receive some guidance as to how I can achieve that. I'm aware of the 'electro-pneumatic regulators,' but they just prove to be too expensive. Cheapest I found was in the $250 area, can't justify spending that much.
If not being able to set a desired pressure, at least meeting three pre-set pressures, say 15-30-60psi, but being able to cycle through those pressures on demand from an ECU. How exactly would one achieve that?
I have a pretty slick manifold with poppet valves controlled by solenoids under my disposal, if someone can see how that can help in this picture.
If anyone's wondering what this is for - it's essentially a new mechanism for a beverage launcher that some of us were discussing earlier. I decided to start a new thread, since that was revolving around DC motors and actuation, which by the way proved to be too inefficient and costly - luckily I was able to return most of the parts. Hence, the new direction.
RE: Electronic Control of Pressure
Use the manifold (rated 350psi) which has an intake and an exhaust port, and 4 other ports. (As said before, I have this under my disposal already)
I would attach 3 manual pressure regulators at the outlet of each port. Set those at desired pressures. Use fittings to connect all the output of the 3 regulators to a storage tank of about a reasonable size(7-10cu-in), and then a quick exhaust valve to connect the storage tank to the barrel. Here is where I don't have much experience; how would I trigger the mechanism and make sure the previous "used" pressure is vented before filling with the desired pressure?
I might be assuming a lot of things here, please go ahead and call me out.
Thanks. That is true. So, there would be a benefit to connect all outputs from the regulators.
Now, the question is would I supply the output from the regulators directly to the storage tank? Would I then set the pressure transducer to read from the storage tank to trigger the solenoid valve, which I would set between the storage tank and barrel, for launch?
A relief valve is also probably needed to be set in the line.
Two solenoid valves.
Valve 1 goes between your high-pressure tank and your launch tank.
Valve 2 vents launch tank to atmosphere.
Control sequence (Starting from zero psi in launch tank).
Open valve 1 for a short time.
Check pressure.
If pressure is too low then open valve 1 for a short time.
If pressure is too high then open valve 2 for a short time.
If pressure is just right you're done.
Repeat until done.
For extra credit "a short time" does not need to be a constant. It can be relatively longer when you are far from the target pressure and relative shorter when you are close - for Valve 1. Opposite for Valve 2.
(automotive automatic transmission)
There's enough flow/leakage in the system that no separate bleed is needed.
Of course, that requires a solenoid that can survive being driven that way.
It would require a single solenoid to control pressure, and a single pressure feedback signal.
Jay Maechtlen
http://www.laserpubs.com/techcomm
Please let me know if I'm overlooking, underestimating something.
Thanks fellas!
I'm estimating 3 solenoid valves, now that gets a little pricey doesn't it? Anyone worked with sprinkler solenoid valves?
Reservoir connected to source cylinder through a bang-bang solenoid valve and an orifice
Reservoir permanently vented to atmosphere through a much smaller orifice
Reservoir pressure monitored using a transducer.
Protect the reservoir with a burst disk (needs to be able to make a much bigger hole than the orifice in the filling line).
Arduino controlling the solenoid valve and the main firing valve in response to the transducer.
Charge your reservoir only in the last few seconds before firing.
When the "Stand to!" command comes, Pulse the filling valve repeatedly (perhaps adapting the pulse length to moderate the filling rate to compensate for pressure variations in the source cylinder). Stop as soon as the transducer reading exceeds your target pressure.
Then monitor the decay in reservoir pressure as gas bleeds off through the small orifice. Trigger the gun as pressure falls through the desired value.
A.
The beauty of the PWM approach is that the set of setpoints are limited only by the resolution of your pressure transducer and the controls downstream. The downside is that you need to put in some deadband, or put up with the buzzing noise.
Relatively cheap pressure transducers are available from auto parts suppliers; they're called oil pressure senders, and typically comprise a variable resistor, whose variable leg is moved by a diaphragm or bourdon tube.
Mike Halloran
Pembroke Pines, FL, USA
A.
You can get a pressure transducer for 20-30 bucks on ebay, look harder.
This setup requires only one solenoid, as I have the multiport manifold already.
I'll prepare another diagram with what zeusfaber listed.
Servo motors are generally very cheap, I know they're usually in the $20 range. Even a stepper would work and they're not bad... $50 tops. The wafer ball valve or something like that, I'm not so sure... I see them in the $40 range on up to a few hundred dollars.
Experience: accumulated knowledge over time.
Talent: the ability to use experience.
Which is more valuable?
Jay Maechtlen
From the CO2 tank to a manifold.
From the manifold to three self relieving regulators.
After each regulator a solenoid valve.
All three solenoid valves feed a second manifold.
The second manifold will feed the surge/storage tank.
Bill
"Why not the best?"
Jimmy Carter
I think you're wasting your time with anything else.
I've gone with a CO2 tank and a regulator, two solenoid valves (one for fill, the other for launch), a pressure transducer which I found for 35 bucks. They're all controlled by an arduino, which was not much of a pain at all to setup.
The system is a little too efficient, to be honest; at only 30 psi it shot close to 50 feet. To remedy that, the barrel length will be decreased, and the storage tank volume will be decreased.
Thank you all for contributing solutions and helping me with this project. Of course, I've only got the launching system done. I still have the unloading of the beverage from the refrigerator to the launching system to still work on, and some programming, so that it can all be controlled using your phone!
Pretty excited. Will keep you all updated.
Curious if anyone has a cheaper/quicker solution to this:
So, the refrigerator and the entire contraption is placed over a lazy susan (it can sustain the weight). I'm trying to automate the swivel. What is the best way to achieve this?
The first thing that popped in my head: http://imgur.com/ddRoymW
Essentially the square box represents the base of the refrigerator, and the inner circle with teeth will be laser cut or CNC'd out of MDF or acrylic. Both of which I have access to. The problem with this is I really don't know how much motor torque I would need. My assumption is not that much - still don't know until I get my hands on the lazy susan, which arrives on Saturday.
Just wondering if anyone has a different solution to rotating the lazy susan 120 degrees and back. Perhaps one that wouldn't require me to use a CNC or laser machine.
Thanks guys.
You need a nice circle of moderate thickness below the fridge, say a 3/4" plywood circle with a nice smooth edge.
You drive it with a timing belt, and a small timing pulley on your motor. You can probably get an XL belt that's long enough.
To keep the timing belt from slipping off the plywood disc, you need a slightly larger aluminum disc below it, and probably one above it just for fun.
To keep the timing belt from slipping rotationally, you just embed two timing pulley teeth in the plywood at 180 deg from each other. For limited rotation, you really only need one tooth, but I'd use two anyway.
I would not, e.g. just cut the timing belt and nail it to the disc or something like that. The belts are not hard to cut, but they are hard to terminate reliably.
If you mount the motor really close to the disk, you may need an idler on the back of the belt to get enough wrap around the motor pulley.
Mike Halloran
How about a used electric window mechanism from a junked car? You could use a link arm from the operating arm to some spot on the plywood disk.
Bill
"Why not the best?"
Jimmy Carter
Sure. I thought you had seen this:
http://www.youtube.com/watch?v=1yl2JWgGXz0
Mike Halloran
Haha. I have. Though, I'm proud that my launching allows for any distance to be accomplished.
Pneumatic is the definition to robustness after this project.
