Containing tools to a specific workcenter
In, well, all of my cells we run into an issue were the specific tool "wonders" away.
The specific one I am focusing on today is Welpers, or mig weld pliers. We have tried chains and they get broken ect and the welpers wonder to another workcenter ect ect. So other than trying a heavier chain, what else have any of you done to make sure the tools stay at the workcenter they are intended for. We have thought of interlocking them to the tip change windows of the weld cell, so the tip change window would have to be on to remove them (extreme but may work well?). I was wondering if anyone has come a crossed an interlock similar to a lathe or drill use for chuck keys (yes that's to prevent them from becoming projectiles, but similar idea).
RE: Containing tools to a specific workcenter
Bill
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
Tom- Don't even know if its a corporate thing or just a general culture thing. Every shop I have worked for has had the same issue to some extent.
Was hoping for a couple ideas anyone has done that seems to have helped?
Check the tool inventory in each workcell.
Where a tool turns up missing,
offer to SELL a replacement to the cell operator at cost.
... but first, be sure the tools are not walking off in supervisors' hands.
If you can catch one, and recover the cost in a way that the rumor mill will detect and disseminate, it may not be necessary to hassle anyone else.
Mike Halloran
Pembroke Pines, FL, USA
Have them bring their own tools. At least a basic set.
If it is just bad habits then train. Train long and hard. Signs on shadow boards. Signs in lunch rooms. Make it a part of the corporate culture like the cop show that ended every meeting with "Be careful out there."
Friday afternoon we all clean up. We quit work at 3:00 and clean, then go home a half hour early at 3:30. I close up and check everything; cleanliness, tools, equipment condition, supplies of all kinds, work in progress, rework (if any). Monday morning I walk the shop and politely, casually, calmly discuss what I saw. E.G. Do we need to have Mark come in rebuild #6. Do we need new tweezers, tape gun, etc.? Do we have enough toilet paper? Do you need a new chair? Isn’t that heater pretty noisy? (A lot of this is pretty small until someone has to make a rush trip for toilet paper. An hour of time lost and it makes, me feel like I am in a Bozo outfit.
We run a “Costco” list. If you are going to need it then write it down.
In the worst case you my have someone actively opposing this. He is probably an unofficial small group leader who is ridiculing the program on breaks, etc. Just keep calmly on message. Eventually he quits or gives you enough reason to fire him. The guy is probably good at something and has the reputation for being irreplaceable. Cross train around him.
Get rid of what you don’t need. Makes it easier to keep track of what you do need.
Is anybody stealing? Do tools end up in the trash? Anybody abuse tools?
Anybody hide tools so they can’t be borrowed.
I spent a few years doing turnarounds for a major corp. My approach was to clearly define what was admirable on everything. We all show up on time. On time means at our work station at the starting time. We all keep our machines clean. We all fill out our maintenance reports. We all make perfect parts. And so on.
It takes a few months of a lot of work but it works.
You have a certain % of employees who really want to do things right. They will listen and really appreciate not having to try and track down their tools. Identify them and then work on the others.
I look at peer pressure as an important part of corporate culture.
Tom
Thomas J. Walz
As for a solution, the best way I found to fix the issue is to have the personnel carry their own tools. Buy it for them the first time if you need to, but charge them for replacement for loss or excessive wear.For some culture BS, I can ask some departments to work like that, but not others. It works in the department where this system was enforced.
Obviously, it isn't economic to apply this method to rarely used and/or expensive tools. I haven't figured out that one yet. We are trying to put a system in place where a worker checks a list of tools before starting a job and then check the list again once he's done. We are having trouble with foremen not enforcing the check list and what to do when tools "disappear" between jobs.
Thanks for the good ideas.
John
We had a worker (who was let go for unrelated reasons) who had over 50 Allen keys in is locker when it was emptied. The guy just forgot the tools in his pocket and emptied them in the locker at the end of his shift. No bad intentions (I believe) but he was not giving a sh*t because no one was responsible for the missing tools.
PS:I know precisely where my pens are :)
buy tool set for each station
create shadow boards for big tools
use custom cut foam in tool boxes for small items
make workers sign an inventory list showing the total cost, let them know they cover the replacement cost
consumables are in a localized, controlled cage/room
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
May be a little excessive though.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
