Wetted parts for check valve 80%-98% nitric acid application: alloy 20.
Our customer is looking to substitute the wetted parts of some swing check valves, currently in 316L. For obvious reasons, the 80%-98% nitric acid solution at 20ºC is making the 316L is melt away like butter on toasted bread.
We're looking to substitute these parts with UNS N08020 (Alloy 20); specifically the disc nut, disc washer and hinge pin. Body material is SS310 (see attached GA drawing). Would Alloy 20 be suitable for these particular parts?
I work with valves in exotic alloys at The Alloy Valve Stockist. This is our blog, and this is me on Twitter and LinkedIn. Let's connect!
RE: Wetted parts for check valve 80%-98% nitric acid application: alloy 20.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Can you send me a screen shot of that particular table. Client confirms 98% concentration at all times, so the 80-98% range isn't valid.
