Materials for family members in part family
thread561-281448: Applying Material and DENSITY within Family of Parts?
Hi John..Your replay on above thread is helped a lot...Is there any otherway to get material density in spread sheet?
Another question is I have assigned material for seed (Template) part thru Tools -> Material properties. And for rest of the parts in same family I manually entered the material and density. Is there any way to make selection of material and its density in the spreadsheet by pull-down ab or other method to avoid manual entry?
RE: Materials for family members in part family
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Assume Washer A and B can be made from Steel and Aluminum.
Step 1: Cretae seed part and assign mateirial steel Tools -> assign materilas.
Step 2: Made Solid body "extrude" to Named and added to choosen columns.
Step 3: Now spread sheet generated with seed part material and density.
step 4: In next row Enter the value for Aluminum and create the part. Thus creates Alum. and steel parts.
Now in step 4 I would like to eliminate the entering values for Aluminum and its density instead of that it should be linked to the Material file and user can choose material easily.
Is that possilbe?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
