Time history analysis for rotating loads in staadpro
Hi
i have a problem in defining load of a rotating flywheel, the flywheel rotates at 200rpm in global xy plane. i want to study the behavior of the structure under this load. Can someone please suggest how do i apply this load in staad and study the response. Thanks
Best Regards
Abhi
RE: Time history analysis for rotating loads in staadpro
You need to so somewhere that people use and discuss your software - This isn't it.
