The attraction between two magnets in repulsion to a piece of metal
Hi all,
I am trying to understand why the attraction between two magnets in repulsion to a piece of metal become stronger when the magnets are brought closer together than when they are further apart. I've run some femm simulations for both when the magnets are closer and further apart and attached the results. Does anyone understand why this is happening? The top(long) rectangle is the metal piece, and the bottom(shorter) rectangles are the magnets (they are in repulsion with their poles on the side or left to right).
Best regards,
Alex
Best regards,
Alex
RE: The attraction between two magnets in repulsion to a piece of metal
- when the magnets are closer, in the region between the two, the magnetic field is forced to a shorter path because of the repulsion, also the part of this path in air is shorter, both phenomena tend to increase the field
- when the magnets are at the far end, there is no more metal extending beyond the magnets, so the magnetic flux is forced to follow a longer path in air.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
Thank you for your reply. I agree with you on both reasonings(if I understand them correctly). However, when I rotated the poles of the magnets 90 degrees(now the poles are on top and bottom) the opposite happens. The attraction is now stronger when the magnets are apart. Please see attached in next post...
thank you. Now I am starting to see it.
