Alternative to Sulfuric acid
We manufacture brass casings for the military. One of the steps is to clean the brass after annealling. This is to remove the oxidation that occurs with a sulfuric acid, then wash. Is there an alternative to using the sulfuric acid that isn't as corrosive, without bringing in carcinogins, strong alkali's, etc.?
RE: Alternative to Sulfuric acid
http://www.crewscorp.com/AR-696Tech.pdf
Matt
Quality, quantity, cost. Pick two.
