Piperack overhead
Piperack overhead
Piperack overhead
Dear Friends,
Is there any criteria for minimum over head height of the fist level of a piperack which there is no equipment and trench under it?
Best Regards,
RE: Piperack overhead
The minimum overhead clearance is based on the type of traffic that will need to pass under the rack.
Is it:
- None?
- Only People?
- Only small trucks?
- Low-Boy Cranes?
- Large Cranes?
- Other?
And the direction of that travel
Is it:
- Length wise?
- Crossing?
prognosis: Lead or Lag
Why do you need any clearance, if there is no equipment or walkway requirement.
If you are going to specify a clearance, why make it anything less than
7'-6"... for minimum standing, walking height headroom.
I hate Windowz 8!!!!
In some projects in some locations and routes, there is no traffic under the rack. Is it nessesary to provide a clearance for walkway or small crane passage for these routes?
I've seen in all of piping handbooks, specify minimum clearance under the rack without considering issues that Pennipiper mentioned.
Brad,
You asked:"Is it nessesary to provide a clearance for walkway or small crane passage for these routes? "
As with almost everything in the layout and design of process plants, it depends! Depends on what?
Depends on:
- What is on this side of the rack and what is on the other side of the rack
- What are the local Codes
- What the Owner/Client says
