IndexError: -1 when running a script through command prompt
Hi!
I am able to run a script through Abaqus, but when I try to run it through command promt I get the error IndexError: -1
My script cycles through paramters and creates and submits a job. When the job is finished, it opens the odb and extracts some values.
I am able to complete the job, but then I get the error.
Any suggestions on what this can be?
Thank you!
Thank you!
