Locke open/cloesed vs car seal open/closed
Dear friends,
What is the difference between locked open/closed valves and car seal open/closed valves? Is there any difference in appearance of these valves?
I tried to find the answer in the net but I couldn't. Could u mind share ur knowledge and photos, if any.
Best Regards,
B.Smith
Best Regards,
B.Smith
RE: Locke open/cloesed vs car seal open/closed
I work with valves in exotic alloys at The Alloy Valve Stockist. This is our blog, and this is me on Twitter and LinkedIn. Let's connect!
Any standard valve (Gate, Globe, Ball, Plug, Needle, Diaphram, Orbit, Butterfly, etc) can have a locking device or Car-Seal added to it. Conversely any valve that had these devices on them, can have them removed and then they are just valves.
prognosis: Lead or Lag
http://www.americanseals.com/meter-seals/spin-wire...
http://www.seton.com/wire-with-crimping-seal-js255...
Locked open / closed means exactly that, i.e. you need a key to open a padlock which is kept secure and only released against work permits etc. Tends to be for safety critical valves - isolation valves for Pressure relief valves for example - to keep them open or closed and stop someone changing the position without authorisation.
The valve looks the same - some hole or other mechanism which prevents opening without breaking the seal / removing the lock. Often seen on valve data sheets as a Y/N option.
