Part Families vs Arrangements in NX 7.5
Hi all,
I am curious what peoples thoughts/best practicies are when it comes to part families and arrangements. I ask this because I am coming across the following scenario again and again at my current employer... I am using NX 7.5 without teamcenter.
If for example an assembly, which comes in various variants has been completed, these assemblies are normally set up with arrangements. This is great for showing just one variant in a 2D drawing view, but allowing all components of all variants to be included in a parts list... No problems so far.
However, if this assembly is then added to another assembly (so it becomes a sub assembly), to show the correct variant of the sub assembly, the relevant arrangement is chosen. Bear in mind that often, only one variant is required in a particular top level assembly at any one time. I personally switching arrangements of sub assemblies, because I worry that someone else one day may accidentally change the arrangement of the sub assembly, and suddently the top level assembly and accompanying drawing needs to be updated.
So my question is, when including sub assemblies into a top level assembly, is it best practice that part families of the sub assembly are used, and not different arrangements? Should arrangements only be used on the top level assembly?
Many thanks in advance
RE: Part Families vs Arrangements in NX 7.5
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Part families are best for hardware items where you have multiple lengths of an identical design. Bolts which you may need to experiment to get your ptoper length is a good case for family tables.
Using part families for nuts makes them easier to control and build since they have an identical shape and you only need to change 3 variables: Width across flats, hole size and thickness.
Ben Loosli
However, there is one small problem (or maybe a lack of knowledge on my part) with just changing the arrangement type of a sub assembly where I am working...
Each arrangement is, where I work, a different product/variant, with each variant containing different parts to the next variant. Lets say the sub assembly file is called 1234567801, and each arrangement is named with a different assembly number (for example 1234567802, 1234567803 etc), making a series of different assemblies that are visible by switching arrangements.
So if I bring in the sub assembly, which contains all parts for all variants/arrangements, I get the part name, part number, material etc on the drawing parts list for all arrangements, but in reality, each arrangement is a different variant of the sub assembly, with different name, part number etc.
So is there something that can be done to give each arrangment a different set of attributes?
Many thanks again
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
