material selection
material selection
Could someone tell me where I would check if materials are compatible with each other and what the governing factors are ie P No group No chemical make up in ASME VII ? appreciate this is a simple question but your experience and help is appreciated this is a learning process for me .
RE: material selection
You mean ASME VIII? The basis for P numbers (someone will correct me if I'm wrong here, but in general its like) a grouping of materials of the same chemical make and same mechanical characteristics.
What does the P-nr according to you, have to do with the original question?
The answer could be simple if you had better defined your question.
Ok for what (purpose)? Corrosion? Mechanical properties, e.g. yield or tensile stresses, thermal conductivity?
If you don't have the original design calculations then you will be hard pressed to justify a substitution.
These alloys are different in strength,temperature limits, corrosion resistance, thermal expansion.
If this is a low temperature, mildly stressed, non-corrosive application then the call is easy, otherwise there is design work involved.
P groups just mean that alloys are handled in a similar way for welding, it does not mean that they are interchangeable.
Plymouth Tube
