"UNABLE RUN ANALYSIS"
in etabs modelling:
i just edited the model from the previous warning. After I address all the warning in the last run analysis, I want to run it again to see if my model is clean. But when I run it, there's a message "UNABLE RUN ANALYSIS". So, I check analysis so that I see whats wrong. But after I address those "too close" & overlaps in the check analysis, I want to try to run it again. But the message is still "UNABLE RUN ANALYSIS". What should I do? Any tips from the expert. Please help. I need to finish my model Asap. Thanks.
RE: "UNABLE RUN ANALYSIS"
that the exact message that will show after i click the run analysis..
I also check the capacity size of the memory of my PC, I have 107GB, its big enough that need in running analysis.
Also, as I have said, I have checked the check analysis.
What i have been thinking, is that my only hope is that, the Import of model is my last resort..
As of now, it still on importing process. It's a big file, anyways.
please, if you have any ideas/ experience/ opinions/ knowledge, feel free to reply.
thank you.
